Does anyone know if the power steering pump from the R33 GTST will work with the R32 GTR rack? I no longer run the HICAS in the GTR and as I’m rebuilding my power steering pump I thought it might be an idea to remove the GTR's tandem pump and swap it with the R33's. It would be a lot neater now the HICAS is out and cheaper to rebuild too. I’m assuming there is no technical reason why this can’t be done?
https://www.sau.com.au/forums/topic/43019-32gtr-33gtst-psteer-pump-swap/
ADM;
search on the forum for previous posts by Sydneykid, he explains everything pretty much in detail. AFAIK the conversion is straightforward but the drive belt needs to be changed; another option might be to use the pulley off the 32 pump? Also the guys at SSS Automotive in Sydney have the details on this conversion. I have an R33 pump sitting in my shed ready to go onto a 32 GTR. Would be interested to know how you get on.
Well, the R33 pump seems to be offset forward when bolted up to the block and the pully is smaller which isnt such a good thing when running at 8000rpm on track days. The pulleys can't be easily swapped, so its back to removing the fins in the back of the tandem pump and plugging the outlet.
Did you use an R33 GTST pump or an R33 GTR pump? Did you use the R32 pump mounting bracket (to the block) or the R33 pump mounting bracket?
I used all R33 GTST parts SydneyKid. It would be possible to fix the offset but Im more concerned with the smaller pulley working the pump and fluid nice and hard during constant high rev conditions
Mmmmmmmmm, I will have to measure the pulleys, I know the R33 GTST pump has lower flow rates, so maybe that's why the pulley is smaller. It was one of the fuel economy and low speed emissions measures, reduce the load from the power steering pump. It would be logical that to reduce the load they increased the rpm of the pump and reduced the torque loading on the impeller.
Since the R33 pump (compared to the R32 pump) has less flow at the same rpm, I don't think you will have a problem.
Thanks SydneyKid for the technical insight (as usual).
I’ve decided to stick with the original pump, remove the fins from the rear pump section, block that sections outlet and rebuild the remainder. It’s not as neat as I would have liked but it saves reinventing the wheel (or pulley in this case) :)
  • 2 years later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
