Hey Guys,
I am selling a custom built catback exhaust for a R33 GTS-T. It is garunteed to pass DB levels as this was its sole purpose for creation. It is extremely quiet and restrictive ( normally everything you dont want in an exhaust) but is perfect if you have been EPA's to slap on and go pass the test with no headaches. single 2 1/4" outlet i believe maybe even 2" lol
FIRM PRICE $150
Located in Melbourne South East Suburbs.
*NOTE* this was made by an exhaust shop with the instructions of mild steel and mig welder then paint black, this will not win any style awards its purely a 1 purpose item but very valuable :)
prefer you to SMS me
0478-410-two four 9
Chris
https://www.sau.com.au/forums/topic/430397-r33-gts-t-epa-beating-catback/
guaranteed??
You'd want proof to show prospective buyers.....
Just sayin....... No offense intended
Do you have any emissions test paperwork? DB reading from a licensed test facility?
guaranteed??
haha yeah paperwork on an item this cheap.
Its garunteed by me, simple as that, i used to work at a reputable workshop so i know this passes as we used to to pass a car that was to loud. passed no problems.
prob should have stated that its a DB test, obviously your emmisions are more dependent on other factors not your exhaust.
Its works, i know it does, if anyone needs one you know where to find it.
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
