Got some what i "think" are s15 injectors
Heres the description i put on e bay
You are bidding on 6 what are thought to be s15 480cc injectors, i was unsure on what injectors these were so had one flow tested at 450cc i assume these are s15's because they don't become 480 without a fuel pressure bump up. So the risk is on you, but that's what they flow tested at well one did.
The injectors are used and in unknown condition, although the previous owner told me they were fine.
These injectors share the same nissan plug and bolt and plug up to rb25's etc etc, should be good for around 280rwkw's in a 6cyl if they are s15's of course.
Note, some of the pintle caps are different and the top part of some injectors have very very small gouges from pulling the stubborn injectors out of the rail, these WILL NOT effect usage.
After $150 for these bad boys, upgraded to 660's.
Q45 air flow metre, big mother, bought from ebay assumed it was new but wasn't used but in perfect working order according to the previous owner so it's all on you no plug incl.
$150 negltiable for that bad boy.
Oil filter sandwhich plate brand new with oil cooler line provisions in -an 10 size, also has 2 provisions for oil pressure switches in standard thread should fit rb's and nissan's alike comes with 2 fittings one in 3/4 which is z145's i think and the other is m20x1.5 which i think will fit sr's etc.
After $30
Next up brand new 7 row oil cooler brand new never used also -an10
$70
Throw me a text on 0430248318 for pics, located in Penrith NSW.
