Mugabetown - Whoretownin' At It's Worst.
Damn!I now I wish I was on bookface.
Yes, Sean called me this morning.
Car went on dyno and in Sean's words 'it was mint on the dyno, just mint'
There are two issues though:
1. fuel gauge has been playing up and was / is reading it has fuel when in fact it doesnt - reads about two needles higher than the E(mpty)
2. there is some reversion (exhaust gases coming back in the exhaust) and something to do with the Exhaust sensor fouling some of his equipment - Sean will fix it
Otherwise, coldstart tomorrow and car should be ready by Thursday :banana:
I am so stoked for Ants. It's been a long process! I guess this means I should book in. The back log is clearing.
Thanks bud. yes, you should book mate.
:bunny::bunny::bunny::banana::banana::banana:
