Mugabetown - Whoretownin' At It's Worst.
Ncis la is cool. So gangster bro.
I was a big fan if NCIS (normal one) but then I got other interests happening like gaming, Sau and car stuff.
Not much time for that in between anymore
Mate, used to have a lot more than 2 TVs. Nice car, apartment, job. Times change I guess.
I sense your going through a rough patch. I'm in the same boat now with only my income stream and things are already tight......sux balls big time!
But I'm just gonna take one thing at a time because my brain looks sooo fkn far ahead that it stresses me so much I can't sleep well and causes high blood pressure issues.
So one step at a time Tony
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
