Mugabetown - Whoretownin' At It's Worst.
sweet. U r welcome to swing passed. But no ant eater :(
Don't know how we're looking for time. Plans are to be at mount tambourine at 12 so, could be cutting it fine. Will let you know though and will definitely call before hand if I am ducking by. :)
no worries mate. Sounds good. Hopefully weather holds up
Nick, Ants sup? I am the same as you Ants. Cannot be farked getting up out of bed
Hai!
not much Michealangelo............still in bed CBF gettin up yet.
Surp wid ya?
Well stuff y'all cause I'm at work and shall be at said work untill 4:30
I'm at work and it's my birthday so stfu lol.
hold up! Arnt ya organising a mega Bday bash for yourself I.e go karting???? If so can't be that bad.......
Also Happy Birthday mate!
Happy birthday bro, and shutup my birthday was Thursday and I haven't had a day off or celebrated since.... Tonight though :devil:
