Mugabetown - Whoretownin' At It's Worst.
Charity Cruise has been moved to the 8th of December,
A number of people who have been critical in the planning process aren't available on the 7th and it's not the right thing to do. Hence we have moved to the original plan of the 8th.
f**king falcoon has a leaking water pump f**k it all what f**king next :angry:
Such bullshit... Why does everything have to f**k up at once. Every time I get slightly ahead with something *finding and buying step 2* something has to break
Mmm being stuck at work serving dipstick flamin mongrel f**k wanker customers isn't helping
Good news is that your day doesn't sound capable of getting any worse :)
How's Anna? Did she go to the Docs?
The doctors said not to bother, they think we found the problem so we just have to wait for it to get out of her system now, They gave a different antihistamine which made her a lot better this morning compared to when she went to bed
Damn it! Colin is selling a reasonably priced exhaust but I am teh broke. I think its time to quiet the unicorn down, I am going to cop a real reaming at some stage if I don't do something about it!
Excellent news! Was it the thing that she mentioned on Faceparty?
The kaki? That's an impressive exhaust if it's anything like their other products.
I dunno what she mentioned on there but it was a tablet she was taking, A month ago she switched from the generic to the regular one and a few days later she was itchy and a few weeks after that hives, She stopped taking it a few days ago and things have started to get slowly better since then.
yeah, i had one on my R33 at one point, was good, quiet with out being too lame.
Will miss how my car sounds now though :'( stupid laws
That was it. Hope that she gets well soon mate. She's too awesome to get ill. Tell her I said that :P
I think by tomorrow morning she will be close to 100% if current progress is anything to go by.
Will do
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
