Mugabetown - Whoretownin' At It's Worst.
Charity Cruise has been moved to the 8th of December,
A number of people who have been critical in the planning process aren't available on the 7th and it's not the right thing to do. Hence we have moved to the original plan of the 8th.
f**king falcoon has a leaking water pump f**k it all what f**king next :angry:
Such bullshit... Why does everything have to f**k up at once. Every time I get slightly ahead with something *finding and buying step 2* something has to break
Mmm being stuck at work serving dipstick flamin mongrel f**k wanker customers isn't helping
Good news is that your day doesn't sound capable of getting any worse :)
How's Anna? Did she go to the Docs?
The doctors said not to bother, they think we found the problem so we just have to wait for it to get out of her system now, They gave a different antihistamine which made her a lot better this morning compared to when she went to bed
Damn it! Colin is selling a reasonably priced exhaust but I am teh broke. I think its time to quiet the unicorn down, I am going to cop a real reaming at some stage if I don't do something about it!
Excellent news! Was it the thing that she mentioned on Faceparty?
The kaki? That's an impressive exhaust if it's anything like their other products.
I dunno what she mentioned on there but it was a tablet she was taking, A month ago she switched from the generic to the regular one and a few days later she was itchy and a few weeks after that hives, She stopped taking it a few days ago and things have started to get slowly better since then.
yeah, i had one on my R33 at one point, was good, quiet with out being too lame.
Will miss how my car sounds now though :'( stupid laws
That was it. Hope that she gets well soon mate. She's too awesome to get ill. Tell her I said that :P
I think by tomorrow morning she will be close to 100% if current progress is anything to go by.
Will do
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
