Mugabetown - Whoretownin' At It's Worst.
I already have an exemption... For a turbo.
And hopefully I'll be buying the NA Saturday. If not turbo it is.
I rather get an NA now cos then if the cars in good nic keep it till I can swap the engine and it'll be sweet
If that's the case, then why not get an R32 and upgrade to a RB25 when you're ready? Lighter, prettier (in my opinion) and a 2L NA won't chew through fuel like a 2.5L NA would.
If you are set on getting a R33 NA, then make sure that it is 100% straight and manual. That way, you can flog the box (lol!) and it will take a beating. Will also teach you how the car moves and then you can put the head on a 30 and boost it - which is not as easy as it sounds but anyway.
It's auto, been re painted. Engine looks in good nic, r32s look weird to me. I can't drive manual skylines. I can't change gears properly and I don't want to learn.
thats not the attitude to have. I will teach u Kath in da GTR!
I can drive manual. It's just that from first to second sucks. Plus city driving is much better in an auto
This is true but you get used to it. If it's a factory or forgiving clutch, then you'll be right. No fun to be had in autos really.
Autos are designed to be more efficient and economical. I know that in mine, if I'm in D, the car isn't willing to stay about 2.5k rpm even when I'm hammering it. Eg: going around a corner pretty hard, you lift and the revs drop right down as it will automatically select the most economical gear. Whereas in tip, the TCU switches to sports mode and allows a lot more free revving. Don't know if the older manuals had this option. Also, if it isn't tip, how are you going to chose the right gear? If you're in traffic and want to give it a bootful around someone at 60kmph, the box will have you in 4th and you won't have the torque there. Just saying, that if you plan on building the car in the future, get as many things right now as possible as parts cost cash. You could be paying up to $1k for a decent RB25 manual box whereas buying a manual now may only cost an additional $300-$500. f**k with it, learn to drive it, destroy the clutch and replace it. You'll still be better off financially.
Don't get me wrong. Autos are great but if you want performance, it should be a manual or a very smart auto box.
  • Like 1
Just to ensure that there is absolutely no sex discrimination at play here... I just discovered that I cannot drive manual either can you allow me to test pilot teach me too lol
just discovered eh? what did you do?.........................have a sudden case of amnesia?
I just wanted to get closer to Kath thats all :nyaanyaa:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
