Mugabetown - Whoretownin' At It's Worst.
Morning all.
It was great to meet Anthony, Melly, Zane, Colin, Tony and the owner of one very cool looking blue R31 at Oktoberfest (Greg).
Big thanks to Anthony and Emelie for the meet and greet at the airport and for taking the time out to catch up with some random from NSW. Thanks Melly and Zane for the lift back to the airport after OF. Unfortunately, I still have rather vivid and disturbing memories of the gold shorts guy and the many cross dressers lol
Ps - Still like Michelle's coffee thanks all for attending the pre drinks :)
  • Like 1
Yeah Zac talked about that yesterday.
Have done many happy laps and mountain runs on standard 4 stud brakes and I make twice as much power as a natro 25... I don't see what all the fuss is about. I've had brake fade issues once at qr and that was on the nation circuit after many stops from a substantial speed
Because I have never had any brake fade issues ever ;)
She won't be carrying anywhere need the speed you or I do when braking into turn 3/4/6, natro 25s stop moving after 120kph
That is true. But she might want to learn to drive fast as well after she gets her turbo.
Good. Couldn't drive it on the road tho :( it's very quiet haha
We can fix that :devil:
Mate just bought a dewalt battery angle grinde, I'll have that sucker setting of car alarms in no time lol
I also have a battery angle grinder...or just remove everything cat-back with a socket set.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
