Mugabetown - Whoretownin' At It's Worst.
Brain strain tho :/ TAFE is so exhausting
I went to TAFE too and had some good days and some very long and boring days as well.
Must say that I learned more out of TAFE than what I did at Uni.
Aghhhhh good ol uni days
no good man.
Oh yeah, but I deserve the ticket... I usually sit right on the speed or follow other speeding traffic.. This time it backfired plus wife found out.. BTW I think it was a ticket from a hand held radar gun and not a van.. seen a police officer squatting in the middle of the highway with a radar gun but no bike or car to be seen... kinda sucks
tafe is awesome learn heaps of stuff then go to pub at lunch, go back and try to learn more.. Southbank tafe was great
