Mugabetown - Whoretownin' At It's Worst.
My diagnosis is blown head gasket. Coolant leaking into the cylinder. Car is steaming like a mofo out exhaust... but then I been wrong again haha
Broken hose above made no different once blocked..
Bring on pressure testing
Wouldn't blocked have the same effect as split, thus no difference.. Or did I misread it and there isa. New line on
no i blocked the nipple off so it wasn't a air leak. the hose only goes to the stock boost gauge sensor.
What is tulle Mel?
Also, have no idea bout the nail polish thingy mingy
Hahaha it's netted fabric pretty much... Often found in skirts of children's fairy costumes or in wedding gowns to make them really poofy...
Ohhhhh bugger. Is your water level down?
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
