Mugabetown - Whoretownin' At It's Worst.
Eh hang around here long enough and it won't matter about broken tags, we're an interesting bunch lol
Many new people? Remember I know most of the people. I have been around these forums for a year or two....
Well, more accurately you'd need to ask 2 questions there:
1. Do I want any experience building LS motors?
2. Do you really need to build an LS motor?
Sean at EFI had those things almost scraping 800hp at the tyres with reliability not being an issue whatsoever
Well... I have a dismantled ls1 motor in my shed and am chasing some decent numbers, but here's the catch *takes deep inhale* We need to do it naturally aspirated due to mod plate BS
Hidden NOS might/may/could possibly be an option for someone (rant proofed lol)
New people, well pretty much everyone man... The club kinda disintegrated within itself after some falling outs that occurred *not to be discussed in public* but yer lots of new guys, myself included I guess.
Only really OG people around now are bunta (andrew) and Ants (er ants lol)... Noel's never around anymore and Dave (rhino rebel) only occasionally pops up.
But us new folk are good value :wave:
Oh ok, Yeah I can build anything you want. Engines I'm not familiar with I just refuse to offer advise on part selection and tech shit really. I'm not going to tell you what cam is best or whatever but all engines are the same on the inside essentially. Some are better designed, however.
Where I'm working at the moment is a Jeep specialist so I've been doing quite a bit of different stuff lately. A few 4.7 Hemis, a couple of 1943-5 Willys Jeep engines and a 1945 Dodge Weapons Carrier. Your LS1 wouldn't be an issue
Don't you love auto correct lol Imagine ordering that and coke in a bar lol
I cannot imagine ordering that beverage on account of the fact it tastes like shit haha!!
Let's see if they filtered out any decent Whiskey?
Lagavulin
Laphroaig
Caol Ila
Talisker
Nick upgrade to a hemi
  • Like 2
They're a super complex intricate mind field maze of an engine definitely super technical and difficult lol
Working for a jeep dealership that's Different avenue man how'd that come about
Animal? Bacon is Bacon....it doesn't come from an animal, it comes from heaven
Homer: Are you saying you're never going to eat any animal again? What about bacon?
Lisa: No.
Homer: Ham?
Lisa: No.
Homer: Pork chops?
Lisa: Dad, those all come from the same animal.
Homer: Heh heh heh. Ooh, yeah, right, Lisa. A wonderful, magical animal.
  • Like 1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
