Mugabetown - Whoretownin' At It's Worst.
t5iv, on Today, 08:26 AM, said:
You at work today?
yes. Got a last minute phone call from one my clients wanting to make an appointment to see me re: acquiring a another business, due diligence, application for finance etc......
with only today and tomorrow left it's not good timing
Tell him to jam it up his finance hole, flip him off and walk out
cant......this is not a small client and also happens to be a client of mine for a long time (getting on ten years now)
One of the others capable of handling it? Business acq DD and apps aren't the hardest but they are time consuming... What if I got you a temp? ;)
Should be alright mate. Thanks for the temp proposal.
I will determine what work is required after the appointment and delegate from there.
I have plenty of colleagues I can count on who are more than capable of handling anything should any urgent matters arise during my absence :)
Plus side: lots of coworkers to smooth things in your absence
negative side: lots of coworkers to steal yer herbs in your absence :P
dont have herbs but do have car parts lol
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
