Mugabetown - Whoretownin' At It's Worst.
t5iv, on Today, 08:26 AM, said:
You at work today?
yes. Got a last minute phone call from one my clients wanting to make an appointment to see me re: acquiring a another business, due diligence, application for finance etc......
with only today and tomorrow left it's not good timing
Tell him to jam it up his finance hole, flip him off and walk out
cant......this is not a small client and also happens to be a client of mine for a long time (getting on ten years now)
One of the others capable of handling it? Business acq DD and apps aren't the hardest but they are time consuming... What if I got you a temp? ;)
Should be alright mate. Thanks for the temp proposal.
I will determine what work is required after the appointment and delegate from there.
I have plenty of colleagues I can count on who are more than capable of handling anything should any urgent matters arise during my absence :)
Plus side: lots of coworkers to smooth things in your absence
negative side: lots of coworkers to steal yer herbs in your absence :P
dont have herbs but do have car parts lol
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
