Mugabetown - Whoretownin' At It's Worst.
Don't think so. Completely different auto-correct function and better feel.
That was my way of saying that it IS powered by swift key with out being a Kent about it. Lol :P
Nice looking car Pete. Details!?
1994 model, which is nice since it has the r33 engine, but the engine is stock bar Tomei M7655 turbos, full turbo back exhaust but no supporting mods eg injectors and AFM's, only making 220awkw's, that is going to change pretty soon though, no point having big turbo's and not using them. Hoping for ~320kw's once returned but will have to talk with Sean first to make a plan of attack.
New clutch in it too, very grabby, taking a bit of getting used to it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
