Mugabetown - Whoretownin' At It's Worst.
Don't think so. Completely different auto-correct function and better feel.
That was my way of saying that it IS powered by swift key with out being a Kent about it. Lol :P
Nice looking car Pete. Details!?
1994 model, which is nice since it has the r33 engine, but the engine is stock bar Tomei M7655 turbos, full turbo back exhaust but no supporting mods eg injectors and AFM's, only making 220awkw's, that is going to change pretty soon though, no point having big turbo's and not using them. Hoping for ~320kw's once returned but will have to talk with Sean first to make a plan of attack.
New clutch in it too, very grabby, taking a bit of getting used to it.
