Mugabetown - Whoretownin' At It's Worst.
good on ya mate. I like the positive energy your demonstrating. Keep it up and I'm certain good things will come your way
Thanks mate. Hoping so. Need to just get in, get my hands dirty and get the job done. Have had chats with the team members and their all loving it. The fact that I don't fuark around, just do what needs to be done, communicate requirements and expectations easily and what not. They've all said that I haven't even been managing, just setting expectations and communicating them effectively which has essentially been perceived as facilitation as opposed to management. Meh, they like it. Work gets done. I'm not complaining. Hopefully I can actually move into a leadership role and more importantly earn leadership kesh monies :P
So who's pumped for the happy laps ?????????
Pick the GTR up tomorrow morn gets dyno'd tonight to see if I make more power with some minor adjustments,
Most of all my ECU issues should be all sorted.
what HP / kW are you expecting the R35 to make bubs?
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
