Mugabetown - Whoretownin' At It's Worst.
Had an issue over the holiday with the boss.
Just worried he might still be pissed about it
bosses get over it but never forget.
Unless you robbed him........I'm sure things will be ok
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
