Mugabetown - Whoretownin' At It's Worst.
This would be an acceptable V8 to put in a Skyline.
Anyone that dosent love how my car sounds is lying to themselves...
Also how can you argue with my STL the other day lol
"Need" to change it... Loud is loud same defect for 95db as 115db
I am going to attempt to get it to legal, and like Titan says, even if it is close, you are less likely to get pulled over. As opposed to how it is now, Anna dropped me at work the other day and I could still hear it idling at the lights while i was in the lift heading up to the next floor. Ridiculous.
Sounds good lol
.... Mines loud, it's a natro V8 deal with it fuzz. I just slip her into top gear and hope for the best when they go past, if they ever pull up next to me at a set of lights I'm f**ked lol
Also, hella old photo of the abomb pre vinyl and v8 ;)
Sounds good lol
car looks blue.........I'm thinking you should vinyl the car blueish like
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
