Mugabetown - Whoretownin' At It's Worst.
This would be an acceptable V8 to put in a Skyline.
Anyone that dosent love how my car sounds is lying to themselves...
Also how can you argue with my STL the other day lol
"Need" to change it... Loud is loud same defect for 95db as 115db
I am going to attempt to get it to legal, and like Titan says, even if it is close, you are less likely to get pulled over. As opposed to how it is now, Anna dropped me at work the other day and I could still hear it idling at the lights while i was in the lift heading up to the next floor. Ridiculous.
Sounds good lol
.... Mines loud, it's a natro V8 deal with it fuzz. I just slip her into top gear and hope for the best when they go past, if they ever pull up next to me at a set of lights I'm f**ked lol
Also, hella old photo of the abomb pre vinyl and v8 ;)
Sounds good lol
car looks blue.........I'm thinking you should vinyl the car blueish like
