Mugabetown - Whoretownin' At It's Worst.
Spotted a pretty nice R33 in roma on the way though from the airport. White series 2 with gold BBS wheels, nice and tidy.
Makes you wonder how many nice ones are getting around out west.
Just saw my first skyline this time in Gatton. White 33 gtr on woodlands road just now. Followed by a white 33 gtst.
White 33 Gtr would be Lukes car, gt35 on a six boost manifold forged cammed 26 goes f**king hard... Nice dude.
White 33 was it parked along woodlands series 1 with a series 2 wing and type m front bar
Yeah I think the gtst was the one you see parked up on woodlands road
