Mugabetown - Whoretownin' At It's Worst.
straight off the ATO website nice one Tony. This ^ is also why this option may not be a viable one..........as the level of audit risk is significant and although would not benefit a tax advantage it from it, it would create unrecoverable time charged............for something the client would not understand.
Nope. From Deloitte. As if trust the ATO. :-P
I am aware of the power that 101 Motorsport car makes lol...
No traction isnt joyous when you are trying to keep it.... Mind you no traction does get the bitches I've heard
when you can do 400m power skids without ever touching the brakes, the bitches be moist.
Happy Valentine's Day to all the sexy beasts out there....
All the not so sexy beasts can suck a fat one.
The good old Hallmark holiday... lol
Aimee & I have been dating for 5-6 years, still never given each other a single gift for Valentines Day. This year aint going to change
Yeah... I got Chants something small. Tyler and I bought her a charm bracelet for Xmas. So buying a present for any occasion now is easy as! :-P
alright mate. Just got a valentines day from my wife...........she doesn't know it but I have one for her two with chocolates to suit ;)
And you sir?
Body chocolate.............
I used to buy my GF jewellery, however she hardly ever wears any so I gave up
Ha, I aint buying a thing lol...
Buy a single rose, a Rembrandts cd and body choclate... The rose may die, and you may run out of body choclate but The Rembrandts will always "be there for you"......
http://m.youtube.com/watch?v=nzQWmAwNNCw
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
