Mugabetown - Whoretownin' At It's Worst.
manual override perhaps Scottie?
Not possible. I wish i knew more about the system to fix myself but i dont. Need to wait for support to call back and fix it.
Looks like its the old pen and paper trick to record sales for now
was I initially gonna say manual ledger book........I should have
Its raining so its pretty quiet so far.
Morning Mr President
How are things on your end? Was reading what you were saying about the systems being down and thought, "who the hell is playing golf in this weather?!"
