Mugabetown - Whoretownin' At It's Worst.
Yeah, 33s have a hard lot in life...
So, I bought a hard pipe kit so I could fit in my z32 afms. And it has no bung for the bov return pipe on the rear turbo, should I just block that line off and run the bov only to the front one?
any idea about that one Andy?
Indeed they are, i'm just more interested in if the ECU will crack a shit when one AFM reads different to the other, or if it causes some other balance issues.
I think i'm just going to blank it off with a bronze plug tomorrow and see what happens (First thought was PVC.. then about 5 seconds later "lol nope that'd melt")
The return is after the AFM yeah? Because if it was in front It wouldn't work. As long as the air is measured then that same amount of air makes it to the throttle bodies you are golden
Never thought I would be staying up till 2am watching a test match
What a day of cricket though. Ryan Harris is a f*cking legend.
Gonna pay for it today though :S
meh test cricket.......efffin boring crap
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
