Mugabetown - Whoretownin' At It's Worst.
Brake talk... Bah
Come on Nick. All you got to do is remove the R and you're in heaven
Sneak peek of my new toy
Looks good Mike. Will we be seeing this at happy laps?
Good piece of machinery the Navara. I bought a new D22 a few months back.... Still havent towed anything with it though lol
Defs keen. Have not much camping gear at the moment, but plan to improve that.
Sweet, Anna and I have most of the cooking stuff needed so if you had shelter and an Esky you would be pretty right.
We just need to find a time to get together and choose our 4x4! with Anna working on the Opera at the moment its going to be 3 weeks at least before we can even go test driving!
Keen for camping. We just steal Christine's mums Navara for it. Navara camping party aww yeah
Well we are out then...I don't plan on a Navara at this point! :P
Edited by Bunta
Anna is the one that drives it most and she wants a more car like experience, and fair enough she spends a lot of time in shopping center car parks ect. I wouldnt mind a twin cab but it doesn't meet the brief. In fact just about the only real 4x4 that does is a Grand Vitara. If that's no good to drive I am not sure where that leaves us!
