Mugabetown - Whoretownin' At It's Worst.
Sounds like a good idea. I am not privy to this motor vehicle you are assembling. All i know is it has a Crank trigger setup [Which im learning more about and jealous of lol] and now e85 with a good fuel setup. Sounds like a cool machine in the making
Its not going to be anything too special, the crank trigger is really just about reliability, after nearly 10 years of cars 'going out of tune' i just want a car that I can turn the key and kick it in the guts HARD every time with out fear of frigging knock lights ruining the fun! At he moment I am capped to running only 14psi with little to no timing, it made 306rwkw then so I am keen to see what the set up is actually capable of with a stable timing signal.
And if I dont like that I will build the RB28 I have wanted for the last 6 or 7 years!
yeah Bunts car should kick some serious bogan V8 ass once she's all done :P
Ha ha I doubt I will cross paths too often with any rigs matching that description, happy laps grand prix is not really my scene!
Is those figures on pump 98? I made another 100hp when i switched to e85 and only added like 3 psi
Strippers FTMFW... Especially Lesbo shows.
This is true
Yeah that was on 98. I think the physical flow of my turbos will be the limiting factor, they are only babies so I think they will be incapable of pushing more air at 350ish kw, though they have been modified from stock so their limit is a bit unknown.
Ants, what's that whisky recommendation website that you use? Also, have you tried Macallan 12 or 18 YO?
Its this website mate http://www.smwhisky.com.au/
Yes, I have tried both Macallan 12 and 18 fine oak and also tried the Macallan Sherry Oak. I also happen to own both ;)
Does it come recommended?
well its Macallan mate. She's like the Nike of single malts its very good stuff but I find the price hard to justify.
Its why in fact Macallan went down the path of introducing the fine oak range because production costs are lower using american oak barrels (bourbon) rather than sherry oak barrels, however even their 18yo was like $189 IIRC.
My thoughts are as follows:
Fine oak - cheaper than Sherry oak and is very fruity, makes your mouth water / dry and then releases beautiful flavors like vanilla, raisins and fudge
Sherry oak - very exy but my favorite but caramel galore. Could really go without that artificial coloring IMO but the tastes - at first its very spicy, but after you have drank a dram you get the following flavours, burnt cookie / creme caramel, spices like cardamin, orange peel and a hint of wooden smoke - truly amazing mate.
you can make your own recommendation but I think you know what to go for now.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
