Mugabetown - Whoretownin' At It's Worst.
And the shenanigans begin... First monthly pay from decmil and I'm pretty sure I've just been paid my base salary with no site loading...
Thats far from ideal. I can see the two figures being very very different
SO, my afternoon and night got interesting yesterday. Was going to head out the the harry's meet cause i was bored as fark... Decided to put the front timing cover back on to make it look a bit better. Marked up the CAS and everything as normal, took it off then put it all back on as normal. Cranked it over and heard a crunch so shut it down and took it all apart again.
After a bit of probing and prodding, I found that the "half moon" nubs in the CAS and on the end of the cam must not have been lined up perfect and it snapped the one off the end of the cam.... Not an ideal situation.
After some head pondering between a mate and I we came to a resolution. We ended up being able to line up where the half moons would be and get the CAS back on in that spot then line up the original markings we made.
Put it all back together and started it up and it cranked over fine and sounded like normal. We free revved it a bit and all seemed good, next was time to take it for a drive and see what it was like under load. We started with normal driving and occasionally getting into boost, all seemed fine. We gradually started giving it more and more throttle and everything was good. Finally we did one last pull, full noise through all 5 gears and it was exactly the same as normal.
Even still I may look into a replacement cam just to be safe..
that's exactly how I busted my CAS Scottie and then car ran like shit.
Get checked over for sure
Its not the cas i broke, its the half moon on the end of the cam that snapped.
And gmorning all
It's Friday :)
And good morning Ants... I actually have tomorrow off sdo i may still head out to happy laps see how things go
oh. I thought the half moon CAS centre was not aligned and snapped!
My bad. Am still waking up
both half moons werent aligned properly and fouled on each other, however when i turned it over it was the one on the cam that decided to snap not the CAS. wish it was the CAS lol...
But yeah as i said a bit earlier there is no noticeable difference when driving the car. So "if" and thats a big "if" its out it can only a a degree or so as you cant hear or feel it.
wait. You talkin about the half moon seals that go on the head not being aligned right?
Its aligned now. Im talking about the half moon that is on the front end of the camshaft. Like pull off the CAS and look in the whole where the centre goes in and locks into place. In there.. See google pic below
thats what I initially thought. And that is exactly how I busted my CAS.
Scotty we have a car in ATM with this bit broken off
The cas is perfectly fine if you get it in the right tooth
Just get a timing light and chuck it on and make sure it's in the right spot before...... Giving it to it
It should be fine that way even with the broken half but it's completely up to you of you want to replace...... Then I buy cam :devil:
    • Nah, turn the boost up, break the gearbox, and enjoy leaving it parked for a few years while you save for a better box...
    • I see those two Stageas have the "punched 40mm hole" deregistered Japanese number plates 👍 Nice kouki group shot with the different colours too.
    • Ended up just being a loose exhaust bolt luckily.
    • Yeah I made that post way too early, sorry I must have assumed it was bad because it's a 20+ year old thrashed shitbox lol. It was just a loose exhaust bolt.
    • Like others have said, drop the power to give your drivetrain a % of reliability until you can up the drivetrain reliability  It isn't rocket science, build power to the weakest link with a % of safety Whilst upping the the reliability of the drive train is costly, there's no point in having the engine make big power if it keeps eating the drivetrain....ask me how I know, I had the tow truck on speed dial for a few years, and I spent huge amounts of money fixing issues and breakages that really would have been cheaper in the long run if I did it right the first time Me, I like a nice sized fudge factor, that keeps me off the tow truck
