Mugabetown - Whoretownin' At It's Worst.
And the shenanigans begin... First monthly pay from decmil and I'm pretty sure I've just been paid my base salary with no site loading...
Thats far from ideal. I can see the two figures being very very different
SO, my afternoon and night got interesting yesterday. Was going to head out the the harry's meet cause i was bored as fark... Decided to put the front timing cover back on to make it look a bit better. Marked up the CAS and everything as normal, took it off then put it all back on as normal. Cranked it over and heard a crunch so shut it down and took it all apart again.
After a bit of probing and prodding, I found that the "half moon" nubs in the CAS and on the end of the cam must not have been lined up perfect and it snapped the one off the end of the cam.... Not an ideal situation.
After some head pondering between a mate and I we came to a resolution. We ended up being able to line up where the half moons would be and get the CAS back on in that spot then line up the original markings we made.
Put it all back together and started it up and it cranked over fine and sounded like normal. We free revved it a bit and all seemed good, next was time to take it for a drive and see what it was like under load. We started with normal driving and occasionally getting into boost, all seemed fine. We gradually started giving it more and more throttle and everything was good. Finally we did one last pull, full noise through all 5 gears and it was exactly the same as normal.
Even still I may look into a replacement cam just to be safe..
that's exactly how I busted my CAS Scottie and then car ran like shit.
Get checked over for sure
Its not the cas i broke, its the half moon on the end of the cam that snapped.
And gmorning all
It's Friday :)
And good morning Ants... I actually have tomorrow off sdo i may still head out to happy laps see how things go
oh. I thought the half moon CAS centre was not aligned and snapped!
My bad. Am still waking up
both half moons werent aligned properly and fouled on each other, however when i turned it over it was the one on the cam that decided to snap not the CAS. wish it was the CAS lol...
But yeah as i said a bit earlier there is no noticeable difference when driving the car. So "if" and thats a big "if" its out it can only a a degree or so as you cant hear or feel it.
wait. You talkin about the half moon seals that go on the head not being aligned right?
Its aligned now. Im talking about the half moon that is on the front end of the camshaft. Like pull off the CAS and look in the whole where the centre goes in and locks into place. In there.. See google pic below
thats what I initially thought. And that is exactly how I busted my CAS.
Scotty we have a car in ATM with this bit broken off
The cas is perfectly fine if you get it in the right tooth
Just get a timing light and chuck it on and make sure it's in the right spot before...... Giving it to it
It should be fine that way even with the broken half but it's completely up to you of you want to replace...... Then I buy cam :devil:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
