Mugabetown - Whoretownin' At It's Worst.
It is cheap, they can be had for 3 parts of f**k all now.
Errr.. Not so much. Maintenance on them isn't cheap at all. You're still facing $10-15k for a 15 year old car that requires a fair amount of servicing and upkeep. That's similar pricing to 33 GTRs, so not cheap.
No matter how you slice it 10k - 15k is a cheap car. Out of interest maintenance wise, what is expensive about them?
All this talk about crank trigger.......and I too know about them benefits thanks to Bunta.
Thinking I now need to invest into one.....for reliability's sake
You are in the position that few of us are though, where everything is new and there is not much movement there, really you should be ok for a while, but if you do want one hit me up and I can get one built for you!
http://sethgodin.typepad.com/seths_blog/2014/03/what-does-its-too-expensive-mean.html Have a read of that and you'll see where I'm coming from.
Gear box is stupid expensive, however that's once every 100k km - hopefully. Plugs are all iridiums (could be platinums now that I think about it), coil packs are about 20% dearer than standard skylines, parts are rarer hence more dorras (window motors, fuel cap release motor, seat motors etc), sway bars are about $350 + shipping from the states because they're difficult to source here, exhausts are more expensive when you include stupid frieght rates. Overall, it all adds up for less performance.
interesting......
You would also change plugs a lot less, be kinder on your oil (not needing to cool turbos down) coilpacks should last due to less heat ect ect. The only one I can see is the extra electrics crapping out but that should be a long way off, I was speaking to Grahame the silver fox and he was saying his costs him fuark all.
interesting......
Ya Rly!
Ya Rly!
Mine's done about 120k km, which is when everything starts f**king out. Hence my level of frustration right now. Oil is still changed every 5k km. Plugs every 50km, which is probably next year. Coil packs are on their way out. Graham has also done significantly less ks than mine has. I think he's sitting at 70k-ish from memory.
Oh, and the bushes are starting to f**k out and need to get them done. and diff feels like it's on the go - not sure though.
All of this whilst saving like a flamin mongrel for a major investment which is due to be finalised in Sept - if all goes to plan. :rant:
Every car shits its pants around then, the little Mazda is about to start costing me money too damn it! But in June it will no longer be my problem so thats ok.
The frustration is amplified when the performance isn't there yet the parts cost more. It's a fun position to be in.
Oh well, you will know for next time!
wasn't aware that most of the stuff had to come from the states - which is what bugs me the most. So in short, it is not cheap. A $15k car that costs a mint to run isn't cheap.
I think the key difference here is your definition of a mint and my definition of a mint is quite different, everything you mention is, to my mind, typical of every car. However I must also say that I don't consider my car to cost a fortune to run either, even when I did drive it daily.
In short I guess I am saying "Damn son, Yo a whinger!" :P
Which is exactly what the link to Seth godins blog described.
Also, I'm going to be in a position in 6 months time when all my assets will be scrutinised, so I'm a little concerned.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
