Mugabetown - Whoretownin' At It's Worst.
It is cheap, they can be had for 3 parts of f**k all now.
Errr.. Not so much. Maintenance on them isn't cheap at all. You're still facing $10-15k for a 15 year old car that requires a fair amount of servicing and upkeep. That's similar pricing to 33 GTRs, so not cheap.
No matter how you slice it 10k - 15k is a cheap car. Out of interest maintenance wise, what is expensive about them?
All this talk about crank trigger.......and I too know about them benefits thanks to Bunta.
Thinking I now need to invest into one.....for reliability's sake
You are in the position that few of us are though, where everything is new and there is not much movement there, really you should be ok for a while, but if you do want one hit me up and I can get one built for you!
http://sethgodin.typepad.com/seths_blog/2014/03/what-does-its-too-expensive-mean.html Have a read of that and you'll see where I'm coming from.
Gear box is stupid expensive, however that's once every 100k km - hopefully. Plugs are all iridiums (could be platinums now that I think about it), coil packs are about 20% dearer than standard skylines, parts are rarer hence more dorras (window motors, fuel cap release motor, seat motors etc), sway bars are about $350 + shipping from the states because they're difficult to source here, exhausts are more expensive when you include stupid frieght rates. Overall, it all adds up for less performance.
interesting......
You would also change plugs a lot less, be kinder on your oil (not needing to cool turbos down) coilpacks should last due to less heat ect ect. The only one I can see is the extra electrics crapping out but that should be a long way off, I was speaking to Grahame the silver fox and he was saying his costs him fuark all.
interesting......
Ya Rly!
Ya Rly!
Mine's done about 120k km, which is when everything starts f**king out. Hence my level of frustration right now. Oil is still changed every 5k km. Plugs every 50km, which is probably next year. Coil packs are on their way out. Graham has also done significantly less ks than mine has. I think he's sitting at 70k-ish from memory.
Oh, and the bushes are starting to f**k out and need to get them done. and diff feels like it's on the go - not sure though.
All of this whilst saving like a flamin mongrel for a major investment which is due to be finalised in Sept - if all goes to plan. :rant:
Every car shits its pants around then, the little Mazda is about to start costing me money too damn it! But in June it will no longer be my problem so thats ok.
The frustration is amplified when the performance isn't there yet the parts cost more. It's a fun position to be in.
Oh well, you will know for next time!
wasn't aware that most of the stuff had to come from the states - which is what bugs me the most. So in short, it is not cheap. A $15k car that costs a mint to run isn't cheap.
I think the key difference here is your definition of a mint and my definition of a mint is quite different, everything you mention is, to my mind, typical of every car. However I must also say that I don't consider my car to cost a fortune to run either, even when I did drive it daily.
In short I guess I am saying "Damn son, Yo a whinger!" :P
Which is exactly what the link to Seth godins blog described.
Also, I'm going to be in a position in 6 months time when all my assets will be scrutinised, so I'm a little concerned.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
