Mugabetown - Whoretownin' At It's Worst.
Back to work at 5am today. Least I get a few days off after that
i hope you do mate. I was going to go to work today as well but feel like shit (nope not hung over and did not even have one drink yesterday)
I cant even remember the last time I had a drink. Maybe 4 weeks ago? Gee I'm getting old
