Mugabetown - Whoretownin' At It's Worst.
Rb26 oil filter change has defeated me. How the f**k do you get the f**ker out. I think i may need a smaller tool to get to it.
It also feels like the filter on there is smaller than the replacement Z145a one i've got, but that could just be tiredness creeping in
Your Tool is small enough
Morning Ants and Scott.
Rain looks like it's going to hang around for a while. Week feels like it's dragging on. Should hopefully place an auditor today!
Morning Tony,
As much as the rain isnt great. We really do need it.
Correct. A massive downpour is a lot more exciting and short lived
Although the soil isn't really capable of absorbing it all at once and a lot of it runs off so theoretically, shorter bursts of rain is better? Where's bunts? He would be able to answer that. He should stop stalking me on LinkedIn and post here :P
Steady rain over a long time, like we are getting, is the best. Not as much runs off and is stored in sub soil. I was 'stalking' you because I was trying to figure out how to stop stuff that doesn't pertain to me being in my feed. I couldn't.
There's a way. When I'm back at my desk I'll take a look.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
