Mugabetown - Whoretownin' At It's Worst.
I'm bored and proposing names for zacs new car
So far "The Lovechild" winning lol
Goon Balloon Mk 2.0...due to it being another Goon Balloon complete with boat trailer indicators.
Second day driving the GTR was really nice.
I forgot how low the car is and managed to pop out the passenger indicator out of its place.
The indicator still works but the mounting point is well........
*Le f**ked*
I have just ordered a new one.
Been an expensive day today with quaife diff and whiteline bushes :/
Well done mate. Looks good
So glad your back out driving this thing now... TIme to enjoy it and rack up them KM's
Do you have an idea of when you will be back for another tune and some E85? or just enjoying it for time being?
Decisions..... For a decent 34 it's 15 and for a amloast destroyed 33gtr it's 14
This makes it hard because either way I will be fixing stuff and changing, and of it's rooted I can fix it so not to much there, and will have a new engine either way....
Hmm
Hmm
I thought that we were just looking for a 33?
well with E85 being so close to me I would like it to be on E85 now.
But it would be best to give it km's first and then once I think it's done enough (maybe 3,000km, so another 2,400kmto go)
Certainly am enjoy it FTM :) :)
But it would be best to give it km's first and then once I think it's done enough (maybe 3,000km, so another 1,500
I agree with you here. Give the motor a heap of KM's on pump98 then give it some e85 when run in has finished.
WHat ECU is it again ? Can it be flex tuned
Hmm
Buy my leopard. Put 33 stuff in it. Massive win.
  • Like 1
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
