Mugabetown - Whoretownin' At It's Worst.
Nah man, Miami, FL
Remy V is for the US domestic market only, Robin Thicke is the ambassador for the brand....check out blurred lines, but only look for the Remy bottles (if you can)
:O
Maiden voyage with rego to work today. Nice to be driving a zed again. Didn't overheat or anything!
And the carpark guy put im in the handicap spot up the front away from the other muppets :D
inb4handicapjokes
Mike you would have been handy at the Tuned Performance dyno day the other week.
Some guy who just bought a Zed got it up on the dyno and smoke started coming out from behind the dash cluster and the wipers etc were going berko when the accelerator was used. Poor guy was devastated and wasnt sure what was going on. It later left on a flat bed
Yeah been speaking to him. Aparantly the alt reg died and let it pump 18v through the system and fried everything. I have to go through the shed on the weekend and see if I can find some computers for him. Auto, pwr steer, abs etc etc
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
