Mugabetown - Whoretownin' At It's Worst.
You just have to come up with a fair vale for the kids so you can buy more scotch :cheers:
don't worry about that, I can make a $2 hooker look like a superstar after I'm done :D
Also just for you Mike
Looks nice. So many to choose from.
I maybe wrong but my instincts tell me that the 125th anniversary will also be a sought after item in the future.
DM just raised their prices to $150 (used to be $129)
I got two of them at the cheaper price.
Get it while it's cheap still
I saw these on facebook this morning and tagged Nick in them for the A-Bomb lol. Seems like good gear. lIsted 700, would be able to get them cheaper i reckon
I just put new brakes with slotted rotors on l, they should work fine simply to pull me up in after 400m of straight line
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
