Mugabetown - Whoretownin' At It's Worst.
You just have to come up with a fair vale for the kids so you can buy more scotch :cheers:
don't worry about that, I can make a $2 hooker look like a superstar after I'm done :D
Also just for you Mike
Looks nice. So many to choose from.
I maybe wrong but my instincts tell me that the 125th anniversary will also be a sought after item in the future.
DM just raised their prices to $150 (used to be $129)
I got two of them at the cheaper price.
Get it while it's cheap still
I saw these on facebook this morning and tagged Nick in them for the A-Bomb lol. Seems like good gear. lIsted 700, would be able to get them cheaper i reckon
I just put new brakes with slotted rotors on l, they should work fine simply to pull me up in after 400m of straight line
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
