Mugabetown - Whoretownin' At It's Worst.
Sarp colon
How goes the pinny cup mobile? Has it been postponed for this year or still planning on getting to a few rounds?
Dad finally finished his escort I got to take it for a spin last weekend and broke the steering rack within 5 mins lol. Stupid wide semi slicks and no power steering + stock rack = not happy lol. It was fun pushing it home though luls
Be lucky to get one race this year I reckon :S. Try to do a few sprints or something this year to get the cars sorted so hopefully we're ready to go for all races next year
Lol, sounds like fun. Did you sell the ute?
A few sprint days sounds like a winner. Pre season testing haha. I need to get myself a car lol. Or ill just use dads, break it and then let him fix it lol. Will keep him busy on the weekends lol
Sell you a Leopard. Is good. Chicks love it.
Or buy a white 32 GTR...?
Ill pass on the leopard lol. I'm keeping my eye out for another 32 but probably wont buy anything until next year. I have to make an effort not to buy a white one but all the ones that come up with goodies are white lol.
Can't remember where the ute went. Pretty sure it went to a young kid on the north side or something. Ill ask dad next time i speak to him. Would be cool to see it running eventually but I doubt it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
