Mugabetown - Whoretownin' At It's Worst.
Who's doing what for origin? We're heading to a sports bar on George St called the Grosvenor. Supposed to be a pretty cool place. ;)
Pretty sure I am going to the game.
I am sick of the swag bellied measles at the Grosvenor :yucky: you get aids walking past it.
The evolution of the gym bro is a great one too. "Yeah I have a problem, its called I can still fit through door ways!"
The Dom vs series is good too
Pretty much my outlook on why I lift lol
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
