Mugabetown - Whoretownin' At It's Worst.
After a few the oil in the SS got so hot after only a few hot laps on the weekend I'm seriously looking into a cooler for it. What are the views on thermostats? Required or not, remembering that my car gets used as a daily.
We rarely get cold enough to warrant a thermostat imo
This is what I was thinking but I also read a lot of posts (admittedly not on australian websites) recommending against running without one. Anyone running without one? Does your oil come up to temp fast enough?
I have had 2 cars without one and had no issues. In the depths of winter I have heard of people blocking some of the flow to the cooler but they were Sydney people.
I guess I could always add one later on if needed.
Greg do you think I was born yesterday, actually don't answer that lol. I'm not into leopards...
Interesting way to go. Same motor that is in the new CLA maybe? I was reading an article the other day that predicted in 20 years there would only be 6 car manufacturers and even the likes of BMW might not be big enough to survive on their own.
http://www.drive.com.au/motor-news/only-six-car-makers-to-survive-20140331-35t39.html
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
