Mugabetown - Whoretownin' At It's Worst.
So all the trouble of boring out a 20 block to fit a 25 head for what?
Its still a 20 head just with a 26 crank and SR20 rods from what I remember of them. The bores are way different 20 vs 25 they're like 80mm in the 20 and 86 in the 25 lol.
So a stroked 20 essentially? Still a dirty 20 then Martin.
Yep essentially that. So you still have to deal with the shit head on the 20.
I can understand the point of it if you want to run in a class that requires original engine, makes sense but you could probably go just as well spending the money on a good turbo set up for it etc.
Run the pinny in street class instead?
That's what I thought, few decent bolt-ons and you're good to go.
That would require registering it with a full weld in cage.
why dafaq you wanna do that???
May as well just put a 26 in it
Bit more capacity, not going to cost that much more than rebuilding a 25 bottom end, I can still use all my bolt ons, etc.
26 into a 31 is a multi million dollar excersize, and I'd basically have to start from scratch. Why the f*ck would I want to do that?
Why? a 60 with hydraulic lifters. I still say 25/30.
See above.
25/30 is a possible option but will probably need a bigger turbo.
Put down the crack pipe and just get a 26?
See above.
If thats the case I'd just stick with getting another 25 into it. extra money spent on the 26 crank would be better spent on tyres and entry fees.
The difference between the two is only 70cc anyway i doubt it will make that much difference
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
