Mugabetown - Whoretownin' At It's Worst.
Well yer, but every girl in toowoomba thinks they're a fkn 10/10. Literally have had girls walk off when just trying to talk to them. Prissy bitches :P
Well stop aiming for the 10/10's.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
