Hi all, I have a set of 4 19" privat wheels off my "00 stagea rsfour.
Has 3 roadworthy tyres, 1 tyre can be rotated as it is only scrubbed on the outside edge. Very light gutter rash on the wheels from previous owner. Inspections are welcome.
Tyre Dimensions are,
235/50/19 rims around 8.5" wide
Offset it 30
Asking $700
I am in the northern suburbs of melbourne. Pm me or call or text me on 0430 074 742
https://www.sau.com.au/forums/topic/431324-19-privat-wheels-off-my-rsfour/
Selling because I prefer the standard look of the car and dont want too much attention drawn to my car as they are fairly large. I will put up more photos in about half an hour as well
If they where in sydney I would take them but the drive to Melb would kill me. They look awesome and can't believe they haven't been snapped up yet.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
