For sale, used R34 GTR Intercooler end tanks with a new Adrad high flow 55mm Core. The core dimentions are 600mm x 270mm x 55mm.
The pressed end tank design of the OEM unit can often fail under bigger boost (20+PSI), as was the case with this one.
The R34 size core is optimized for twin low mount smaller turbo's, say up to -5's.
The Adrad core design is much freer flowing internally with very low restriction (pictured), however with a smaller core size such as this it was limited to 380kw. We wanted to make more, so this core was swapped for a 100mm core. The intercooler has only done 10x dyno pulls.
$850 firm = less than the cost of the core and fabrication cost.
Pickup from Bayswater, or freight at your cost.
