1995 Nissan Skyline R33 GTS-T, i have owned the car for 3 years and have done all the work on it, making sure it is all done perfectly with quality parts.
500kms ago i had the head rebuilt with cometic street pro VRS kit, all surfaces machined and fitted ARP head studs too. find below some of the modifications.
looking for $13,500 ONO and swaps are welcome
would consider S15, 180sx with cash, etc etc
ENGINE / TRANSMISSOION:
* RB25DET with 165,000 kms very healthy motor
* dyno tuned 3 weeks ago at 373HP on 17psi.
* FMIC
* 740cc injectors
* freddy plenum
* BRISK performance spark plugs
* walbro GSS-342 fuel pump
* all new vacuum lines
* nissan thermostat replaced 500kms ago
* gates racing timing belt, and pulleys replaced 500km ago.
* water pump replaced 500km ago
* cometic head gasket 500km ago
* ARP head studs 500km ago
* full head rebuild with receipt 500km ago
* stainless steel high mount manifold with screamer
* TIAL 38mm wastegate with 1 bar spring
* Kinugawa TD06-20G turbo 500km old
* custom braided lines for turbo
* 3" stainless exhaust, high flow cat.
* o2 sensor recently replaced
* always used fully synthetic AMS oil 10W-40
* KN oil filter
* DRIFT pod filter
* aluminium radiator
* blue silicon rad hoses
* apexi power FC with hand controller
* Greddy profec B series ii boost controller
* turbo timer
* locked Diff
SUSPENSION/ WHEELS:
* near new GREDDY coilovers all round
* rotoa wheels
* Achilles tyres brand new 50km ago
* new QFM A1RM brake pads front and rear
* cusco strut brace
* KKR rear camber arms
* recent wheel alignment
INTERIOR/EXTERIOR:
* m spec body kit
* HID head lights
* LED parkers
* LED number plate lights
* pioneer head unit
* series 2 dash surround
* new jdm gear knob
* JL audio rear speakers
* sony xplode front speakers
* momo styled deep dish steering wheel with HKB boss kit
* carbon fibre boot lip
BAD POINTS:
* small amount of rust in both rear guards
* the roof has some small patches where clear is visible
Thats all i can think of at the moment, im sure there is alot more i have forgotten to mention, i have receipts for pretty much everything done to the car and it is serviced every 5,000 kms.
the car is in great condition inside and out, i dont really want to sell but if i get my price or a good offer as a swap then i will. inspections welcome, no test pilots or time wasters please.
for any questions PM me on here or call on (Contact Seller)
car also comes with rego
https://www.sau.com.au/forums/topic/431809-qld-63wiz-r33-gts-t/
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
