So ive been searching around for awhile in topics related to ABS units on r32 gtr's as mine has started to leak. Found a few threads on people deleting them completely etc but i plan to just replace mine with a newer unit that i recently picked up. Couldnt find any guides with pics on people deleting/removing their abs units so ill have to figure that out myself when i install my new brake pads, rotors and replace the fluid.
My dilemma is, ive always been told not to run the BMC dry, ok fair enough ive looked that up and seen how much pita for some to get it back working 100% again, but removing the ABS unit and putting the new replacement in will obviously end up having some air get into the system once i reconnect everything and clean up the mess and ive seen few mention that getting air into the abs unit itself is also a problem and a half to fix and get the air out.
So my question is, if anyone has replaced their ABS unit before, did you run into problems bleeding the system after and getting air out of the unit? or was it simply replace unit then bleed system and all fine and dandy again?
Cheers,
Dee
I did mine. Was a PITA to get it fully bled again, but quite possible. Just kept bleeding until i had a hard pedal. I used a vacuum bleeder on the ABS itself - not sure if that's necessary tho.
How many bottles of brake fluid did you end up using and how did u use the vacuum bleeder on the abs itself? Haven't used any of those bleeder tools before usually just normal gravity bleed but in this case I need to make sure as I'm changing rotors and pads at the same time wud be embarrassing taking it out to bled in brakes and neck minut cant stop haha
Cant remember how much fluid i used but i always have a couple of 500ml bottles on hand. I also usually just gravity bleed but due to the ABS nipple location I got the vacuum bleeder. You just put the hose on the nipple, release it a bit and pump away.
I would do the pads and rotors before or after, just to separate the work to simplify it.
Also you shouldn't ever get in the situation where you cant stop - dont take it out until the pedal feels right ;)
haha well was over exaggerating with the cant stop situation, wudnt risk my car like that =P and cheers, i only recently found out about the abs unit having bleed nipples so im assuming as its located on the top, gravity bleeding it prob wont work? ill buy a vacuum bleeder if thats the case. Probably also get 4-5 bottles just incase and do the pads and rotors after the unit is bledded in and entire system flushed.
Thanks for all the help =)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
