  • Replies 250
Hi everyone my name is Stuart
Age 29 (Male)
I live on Buderim Mtn on the Sunny Coast
IT Tech (Own Business)
I own a Metalic Blue Gst-T R33
Mods Inc:
18" wheels
4" Cat back Exhaust 6" tip HKS Super Drager
Cut Speed Limiter
Turbo Smart 2 stage Boost Controller
Turbo Smart BOV
2X 12" fusion Subs, 6"Infinidy Splits & 6" Pionieer 3 ways
Pionieer 400 watt 2 ch & boss 800 watt Amps
Anyone wanting to meet in the Mooloolaba Area or something
just let us know.
https://www.sau.com.au/forums/topic/432-qld-members/page/5/#findComment-20462
Originally posted by peteSmith
u will tomorrow. i am definately going to bwcp tomorrow night.. i think we should all try and meet up this time.
Can't.. it was andrews 21st yesterday and this weekend is full of birthday dinners and party's..
Next weekend for sure
I'll be having withdrawal symptons by then :burnout:
https://www.sau.com.au/forums/topic/432-qld-members/page/5/#findComment-20522
nismo girl.. look like a no go..
i was meant to pay the deposit on it today and pick up tomorrow.. so i go to the bank and ask if i can withdraw money.. the r like sorry no money.. and i know there is 20,000 in my account as it was just deposited... anyway to cut a long stroy short they couldnt work out what was happening and transfered the money into my etrade investor account.. so now my bank account shows -$15,000 !!! and i cant get the money back from etrade till thursday!! so unfortunately it looks like ages till the next 'right' one comes along..
i hope that makes sense.. i am not thinking straight.. the worst day of my life.. i almost missed my most important uni exam waiting at the bank, i was late to work after going to the bank after my exam and i curbed the f**k out of the passenger wheel while delivering pizzas tonihgt.. i need something to hit now!
https://www.sau.com.au/forums/topic/432-qld-members/page/5/#findComment-20630
Guest Boxhead
one of my close friends father is like a australian champion for clubman series or something.. and i was talking to her about converting myn, and she basically said, dont even think it, its just too expensive in long and short run....
but thats only what i have heard, i rekon nizman should sell, and buy a manual, good luck to you mate..
https://www.sau.com.au/forums/topic/432-qld-members/page/5/#findComment-23813
this relates to a r32.. and was done in sydney, but may help
http://forums.skylinesdownunder.co.nz/show...+and+conversion
" I ended up getting a new heavy duty clutch, a Daiken, so the cost was a bit more than planned, plus a little extra for unexpected difficulties, which seems to be the case whenever my car is serviced, modified etc
I ended up paying 2350 inc the clutch for the whole job, which also included new gear box oil, and replacing some rubber boots and things on the box as they were cracking. "
https://www.sau.com.au/forums/topic/432-qld-members/page/5/#findComment-23996
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
