  • Replies 232
XVelo, everyone is welcome.
GOR33, we will have a membership sign on for the day, so bring your money with you.....
Polish the car clean her up and enter the peoples choice competition or even the show and shine. For the stereo heads we might even have a sound off, but we don't have any equipment to actually measure the dB so it might be just a thumbs up type of thing.....who knows the possibilities are endless...
Cheers
Gary
for those who want to see the first club shirt here is a horrible picture of me at the last skid pan day wearing it. This is nearly exactly what it will look like, (without my ugly mug in it) only a few little logo colour changes, you won't even notice.
Samantha,
Not too sure on the design of the ladies shirt at the moment, we are having difficulties with the logo's on the ladies polo shirts so we are looking at different alternatives. I will probably have a style by mid next week. If there is a style you would prefer please email me a pickie and I will see what I can do. Otherwise I will post something up in the next few days.
Cheers
Gary
HI Erin,
It's the shorter length sleves that we are have trouble with.... We can't fit the logo's on easily without resizing all the logo's which incurrs another set up cost which blows the ladies shirt cost into the rediculas (spell check). We are currently looking at some different styles of womens polo's, some with colars some without, vee necks, all that sort of thing. Erin if you have something give me a call and I will see what we can do to match it.
For all the ladies that want shirts I will eventually need your sizes simply because I will not be mass ordering them. Therefore let me know how many you want too... But I will post something up to show you what they will look like before such time...
Cheers
Gary
shirts look mad, and just a suggestion, can there be something organised with the autobarn chains around gold coast, they have a good db meter that they use, maybe they will cum out for the day and do the sound off, i know the guy at the burliegh store who organises their sound offs, maybe he can help us?
dont know just a suggestion,if we giv them sum advertisment on the day then they might return the favour with organising the sound off? i can go and talk to him if u guys think it could work?
Gary, that photo makes your license look like a glamour shoot!! :D
How about a category for 'most unfinished modifications'? I'm a shoe-in...
any word/pics of the ladies tops?? :)
I wanna see the ladies' tops too ;)
We tried to get Autobarn on board but they messed around for ever so we gave up on them. All they were prepared to give was the same as what everyone can get by joining their 'Autobarn members' which every Tom, Dick and Harry can do. So we decided to work with people who will treat you well and really look after you.
Cheers
Gary
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
