RB25DE (Non turbo) -
After not starting for a day seems to always start/crank over very slowly and lumpy, after about 3 minutes of trying to start it, it runs but very lumpy and misfires for 5-10 minutes then returns to normal once warmed up to firing on all cylinders... Once started and running it also spits out a bit of water/fuel
Was told it was coil packs - Checked and changed, still does the same
Was told Spark Plugs - Checked and changed, still does the same
Was told Air Flow Meter sending wrong signal if dirty to the ECU - checked and no problem
Was told Fuel lines, if fuel was going into cylinders - Checked lines putting normal amount into fuel rails
Was told head gasket, checked radiator and empty'd the water out just to start it over a couple days without water (to eliminate the fact that it could be sucking in water from radiator, would start normal and fine if it was a head gasket problem with no water, still started lumpy and the same) - Also had plenty of water in radiator, almost full didn't lose any
Was told that it could be faulty injectors, leaking or dripping over night then when started it not running properly due to an ''overflow'' or too much petrol in cylinders hence the lumpy/misfire until that petrol is burnt up.... thought id still post incase anyone knew for sure what it was
Could it be a possible blocked injector problem?
Keep in mind that the problem goes away once warmed up :/
Anyone come across this and know for sure what the problem is??? been bugging me for so long!
Videos of each problem listed below... Although i'm sure they are both related..
Crank over/Start problem -
Running/Misfire problem -
Sorry for long post! really can't figure this one out :/
Just out of interest, does it help starting if you jump start it with another car?
Haven't tried to jump start with another car, but I have tried using a big jump start battery pack with big leads coming off and it didn't seem to make a difference
Quick update... took injectors out and had them pulsing through a bath, increasing the speed etc... cleaned and put back in then a day after no start it did the same, one other thing that iv'e been doing to help find out the problem is have the cover that covers the coil packs removed, and while it is running lumpy and misfiring i removed each coil pack plug/loom one by one trying to find out which was misfiring, for example if i removed a plug and it ran worse, then it tells me that the specific coil pack is working, and if it doesn't effect or make the car run work when i remove another plug I know it is THAT specific one/cylinder that isn't working..................... Done that procedure a few times, whenever it ran lumpy or misfired and it isn't a consistent coil pack that isnt working, it will sometimes be the 2nd coil pack, and the 5th then the next day will be the 4th coil pack only or something... seriously out of ideas :/ and I have had the coil packs replaced with different ones by the way.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
