First checkout the link below for proof I can be trusted to post as I'm an ebay POWER SELLER:
http://feedback.ebay.com.au/ws/eBayISAPI.dll?ViewFeedback2&userid=iphone.addiction&ftab=FeedbackAsSeller
As seen in the photos I have a BRAND NEW Extreme Torque Split Controller (TSC) for Nissan Skyline GTR, GTS4 & Stagea.
Sells for up to AU$450, I'm letting it go at less than half price!
Are you finding your Skyline GTR, GTS4 or Stagea just a little “tail-happy” through corners even though it is a 4WD vehicle? The Extreme TSC will overcome this by allowing control of the amount of torque supplied to the front wheels.
One of the most effective performance modifications you will ever make.
The Skyline GTR, GTS4 & Stagea have an "On-Demand" 4WD system (ATTESA) in which a computer and a number of sensors decide how much torque to apply to the front wheels. The system often does not apply the ideal amount of front torque as it is greatly dependent on weather, driving style, track surface and simply because it is a very RWD biased system.
The Extreme TSC allows greatly enhanced control of this torque split by providing a user adjustable dial that allows control all the way from standard operation to maximum allowable front torque split which provides a feeling of full locked 4WD. This is accomplished by manipulating the G-force sensor signals to "exaggerate" what the computer sees. This results in much greater control of the vehicle(especially in the wet) and can also substantially improve lap times.
A 2WD/4WD switch is also provided to totally disable front torque for those times when "drifting" is required(Important: switch should only be used on R32 GTR's and GTS-4's).
The use of an Extreme TSC is often regarded as one of the greatest handling modifications that can be performed. Suitable for use on R32, R33 and R34 Skyline GTR's or GTS4 and all Stagea models.
Requires just 4 simple connections (very basic soldering skills required). It does NOT require professional installation as it comes with very comprehensive installation instructions. The main control box sits under the console close to the G-sensors and the controller can be mounted anywhere you like (cable approx 1m).
YOU MUST CONTACT ME BY PM OR EMAIL
Price = $200
Pick up from Wyndham Vale VIC & sometimes Dover Heights NSW
Postage with Tracking $20 or with Signature $23
Contact Brett
[email protected]
Edited by Sydneyactionman
